Configure ACE IPv6 next header entries to have the filter look for specific next headers.
The ACL exists.
The ACE exists.
- Select Advanced Filters (ACE/ACLs).
- Select the ACL tab.
- Select the appropriate ACL.
- Select ACE.
- Select the appropriate ACE.
- Select IPv6.
- Select the Next Hdr tab.
- Select Insert.
- In Oper, select the operation type.
- In NextHdr, select the next header type.
- Select Insert.
Next Header Field Descriptions
Use the data in the following table to use the Next Hdr tab.
Name |
Description |
AclId |
Specifies the ACL ID. |
AceId |
Specifies the ACE ID. |
Oper |
The eq parameter specifies an operator for an “equal to” field match condition. |
NextHdr |
Specifies the next header of the IPv6 header. Specifies hop-by-hop, tcp, udp, routing, fragment, ipsecESP, ipsecAH, icmpv6, noNxtHdr, or undefined. |
